If I do that while setting up, how do I zero out the rotations then?Both, pull or rotate a bone. If you rotate a bone its tip joint rotates as well.
Also, yes, the tip bones are out of whack on the hand set up. They don;t orient when I use Orient Joint, so I guess that has to be done manually.
