Joint Binding question?
I have a little guy and he needs two bones only. Just for his right upper arm and right forearm.
What is the best binding method to avoid a lot of weight painting?
This is all I found in the Help:
max. influence: The max. number of joints which can influence a mesh vertex. Values of 2-4 are normally enough.
dropoff rate: The dropoff rate of the influence of an joint. The higher this value the faster a joint will lose its influence on vertices.
bind mesh: Click on the "OK" button to bind the mesh to the skeleton. Performing this command calculates the vertex weights for each joint.
Thanks I don't really understand max influence. or drop off rate:
PS: This Guy is one mesh.
UncB might this help you?
Starting about 2:45 minutes into the video Andrew explains quite well how to Weight Paint (Vertex Paint) a Skeleton.
The Video is listed in the Cheetah Help Menu Under Tutorials. It’s title is: Character Animation (online)
https://www.cheetah3d.com/download/videotutorials/anim_tutorial.mov
Novolume has a good free Cheetah3D Rigged Character Model Video Tutorial in his website
http://www.mac3dsoftware.com/cheetah3d/free-cheetah3d-rigged-character-model/
My Best
Jeanny
Oooops! :redface:
I listed the wrong web page for Andrew's video.
Just in case you tried to go to it before I had a chance to correct it -
I now have the correct url listed in my first post.
Oooops! :redface:
Thanks for the help. I am familiar with these videos,
It is easier and can be a bit more accurate if you weight paint in point mode.
Neither of these videos address or explain the two binding methods.
Pod's book has some excellent joint information this is a good tip on P.430
You can scrub your test animation to a point where a deformation occurs and then paint vertex weights with the mesh in it’s problem pose until the problem is fixed.
Again Thanks Jeanny.
Unc808,
That sounds interesting.
Wish someone could add some light on the subject.
Thanks for the tip on Pod's Book. I have the book and I'll have to look it up.
My Best:smile:
Jeanny
I´m not sure if just 2 bones is enough if you want to pose the shoulder upwards.
I´d add/start at the clavicle->shoulder(Greater tuberosity) ->elbow->metacarpus (middle of the hand). You´ll need to "unpaint" the whole body from the first joint.
Here´s an example on Andrew´s defencelessly Alien:
  • One arm Alien.jas.zip
Here´s an example on Andrew´s defencelessly:
I wasn't going upward but that is good advice if I were. Thanks Frank any info on What is the best binding method to avoid a lot of weight painting?
Distance or Heat? What is the difference between the two?
Is it possible to use neither but just manually weight paint. here's what I got trying that.
Since we have "Heatbinding" I really never used the other method anymore.
I made this from scratch - no weight painting at all. Will this work for you?
I doubled the mesh+joints and add a Distance bound version just for comparison needs. No post work. All out of the box.
  • HeatBinding.jas.zip
