New User
New User
Hello,
I am a new and naive registered user of Chetah 3D so bear with me please. I first followed the initial practice recommendations and I can not see the Materials Texture (LOAD) button after I choose the material. I am sure it is a simple thing.
Thank you in advance for your help.
Best,
Jimmy:smile:
function DOMContentLoaded(browserID, tabId, isTop, url) { var object = document.getElementById("cosymantecnisbfw"); if(null != object) { object.DOMContentLoaded(browserID, tabId, isTop, url);} }; function Nav(BrowserID, TabID, isTop, isBool, url) { var object = document.getElementById("cosymantecnisbfw"); if(null != object) object.Nav(BrowserID, TabID, isTop, isBool, url); }; function NavigateComplete(BrowserID, TabID, isTop, url) { var object = document.getElementById("cosymantecnisbfw"); if(null != object) object.NavigateComplete(BrowserID, TabID, isTop, url); } function Submit(browserID, tabID, target, url) { var object = document.getElementById("cosymantecnisbfw"); if(null != object) object.Submit(browserID, tabID, target, url); };
I may misunderstand your question but:
* to apply a material to an object (either an entire object or a specific selection of polys) you simply drag the icon from the materials panel to either
1 the object in the view port
2 the object in the object browser panel
Servus from Vienna
What does a naive bear have to do with all this ?
Pooh! :tongue:
Thank you!
Right! Thank you so much.
I was just looking at the first tutorial in the manual and it showed a dialog box "menu" that was suppose to appear after a material was selected that allowed one to modify texture and it showed a load button.
Here is the text from the first tutorial making a world map.
"material: To add the world map texture to our newly created material click onto the word"texture" at the right side of the diffuse channel.
A menu will now pop up.Please select"Textures ->image". This will connect a image texture node to the diffuse color channel.
The texture properties will now be visible.Toload the texture click on the "Load"button. Use the image file that contains the texture you want to map onto your world."
I must be missing something when I try to follow the directions.
Jimmy:(
Ooops, I did, indeed, misunderstand the question.
Hang on a tick and I provide a short screen shot.
* Click on the material you have selected
* in the Properties panel, next to the diffuse parameter (and others) you notice a square indicator button
* click on this button.
* the texture panel opens where you can load (remove, edit) an existing texture and set the required parameters
* the OS opens a dialogue where you can select a texture to apply to the material
Servus from Vienna
Depending on the complexity of the material, you may want to use the node editor to apply C3D textures. There are numerous threads on this topic in the forum.
New User
When I click on that box only this comes up:
New User
Please ignore the text above photo.
Jimmy
A Gradiant is a filter and not a texture. As such it is dysfunctional without input nodes. There is a Q&D (quick and dirty) intro to the node system available in the forum (check the tutorial section) which gives you a general idea of the tool. It is quite complex and requires some grasp of medium math(s).
* I suggest that you describe exactly what you want to achieve and possibly post the .jas of you model.
Servus from Vienna
