Decorated pig
After following your instructions I do not get your second image but still: 12 0f 12. Can not figure this out...I never get a read out containing the number 46.Mine always says 1 0f 12.
What browser and OS are you running? I know all of the Snow Leopard browser are basically not being supported anymore. Not saying that is the problem, but it is my first thought.
Have you tried clearing History/Cookies/etc.? Maybe even dump the preference file for your browser, or least back it up and so a new one can temporarily be made.
I suspect its this.
1. go to 'User CP' at the top-left
2. click on 'Edit Options' near top-left
3. go to 'Thread Display Options' half-way down
4. Go to 'Number of Posts to Show Per Page'
5. in the dropdown menu, choose 'Show 10 Posts per Page'
6. Click 'Save Changes' at the bottom
Hope that works for you.
--Shift Studio.
I have just the defaults enabled like most others I guess . and it works all the time:
@ Frank. I have mine at 40 so that there are less pages to flip through.
Works fine too. I suspect uncle808 does as well, but forgot.
Mystery solved?
Let me conclude: if you have enabled 40 posts per page this particular thread is just 12 pages long! If you use the default setting like me it´s 46 page long.
So it´s always better to link to a certain post than to a special page, because of these settings it may differ.
Yes Thanks to all. Mystery solved. Thanks again everyone forgot all about those settings. Don't go there much.:icon_thumbup: :redface:
Another question about materials:
Is there a way to tell Cheetah where you want to Save/Install new materials does it have to be in the library folder. I want to sync to two computers via Bit Torrent sync so I need a shared folder is this possible?
Can't you just sync the '~/Library/Application Support/Cheetah3D/' directories?
By the way — thanks for asking that question :) Resilio Sync looks like a fantastic system for managing backups.
I use it all the time plus no cloud involved or internet. but both Macs must be on to sync I also use it to sync my iPod and iPad. (I stay away from messing with my '~/Library/Application Support/Cheetah3D/' directories? I don't know enough just enough to mess everything up. A little knowledge is a dangerous thing.)
Porcelain Pig with Bubbles
Porcelain Pig partying on a black spray painted wood post.
The bubbles aren't quite right, but maybe will give someone else a starting point.
  • porcelain_pig_with_bubbles.jas.zip
Brighter bubbles
Brightened the reflection on bubbles.
  • porcelain_pig_with_brighter_bubbles.jas.zip
Porcelain Party Pig got carried away
Rendered with 7.x Falcon
Bubble material:
I used the directional texture for the spectrum colors and piped into a
State I-N (incidence angle?) mix to control the transparency, index of refraction.
For some reason, setting the emissive helped the appearance, but I'm pretty sure it is not technically accurate.
If anyone has some insight on how to make a more accurate bubble material, I'd be interested. Though I have no idea when I'd use it for a real project.:)
Bubble material:
Nice, I think this material is much a like a diamond material. We'd really need a dispersion effect to be able to fully do it correctly. But I think it looks pretty good the way it is.
Bubble material:
I like your version of bubble material. I like the color effect the directional node creates.:icon_thumbup:
Here are two posts from others on the forum who were interested in creating bubble material.
http://www.cheetah3d.com/forum/showthread.php?t=7849&highlight=Bubbles#top
http://www.cheetah3d.com/forum/showthread.php?t=6581&highlight=Bubbles#top
:D Thanks for posting your version of bubbles.
My Best
Jeanny
Bubble material:
Hi, good work so far!
For the weak spectral colors I would just use a noise with a chromatic gradient, mixed with 95% white.
You need to tweak the noise scale according to your bubble diameter.
The bubbles need some thickness (shell modifier).
misoversaturated, that's great. Thanks.
I do like the random nature of the spectral colors using your technique.
Jeanny, thanks for this link. Frank mentions the same thing as misoversaturated about adding some thickness to the bubble wall.
Looking back, thats the same effect I was attempting by using the State I-N to set the Index of Refraction and Transparency.
That will look realistic only with a negative refraction (<1.0) which cannot be chosen as a node parameter.
But you can make the bubble object editable and flip normals (turn inside out).
Then you use the state i-n with a small power function exponent (for thin film thickness) and use a multilyadd node so that the refraction index is 1.0 over the middle and increases towards the edge.
Also you cannot use the dielectric material because it won't show realistic reflections;
use the default material and a transparency <100% with full reflection and fresnel.
misoversaturated, where did you get your knowledge of the nodes? (really meaning, how the heck do I get that knowledge? :smile: )
