How does snapping work?
I've read the manual, and it seems I didn't understand how snapping works. First of all, I enable snapping in the transform tool. I set the snap space to "global", and enable "points".
If I try to snap the axes of a folder object to vertices in the scene, it doesn't work. I tried to convert all objects into editable first, but it didn't fix the situation.
Then I tried it with cube objects. Sometimes snapping worked with these, but most of the times didn't, and I think the settings were the same all the time.
I also tried to snap to spline objects. I didn't succeed with these either.
Can you enlighten me? What exact steps must I follow for:
1) Snap the axes of a folder object into any vertex of the scene (polygon vertices and spline vertices)
and
2) Translate an object (as a rigid body, without deforming it) so that one of its vertices snaps to the vertex of other object (polygon or spline).
Thanks for any suggestion.
and
