Using modifier for one STL is the best solution?
I have created a 3d model in STL and another service (DesktopHero). It exports an STL file.
Now I am trying to edit it with Cheetah3D.
I want to modify the leg size to represent the various stages of the lipedema disease. As seen here:
I thought of using the modifiers (bulge?), but it modifies both legs at the same time, and partially even the hands.
What is the best solution for this?
I wish to 3dprint those models later.
I don't understand why this model is already in STL format.
I'd probably use soft selection in point mode in combination with normal move.
Or the brush tool.
* Existing modifiers seem to provide no clean solution.
* Same as Frank: I suggest point recording. Either select clusters of polys (tris in this case) or see if soft selecting points is useful. Then apply a normal move.
* Expand / reduce the selection as determined by the growth of fatty deposits in subsequent keyframes.
* PS re point recording: The topology (in the sense of number of faces / edges / points) must be static from start to end. Do not add any geometry during point recording.
Or the brush tool.
thats the format exported by the app, I can change it to whatever better format, but to 3d print later I will need to export as stl again
I understand - but I'd keep on working with quads until I'm finished and there's no need to triangulate the mesh, because this will happen during the export process to stl.
* Your current, fairly fine grained (STL tris based) topology of the body may not simplify modelling subsequent steps in animating lipedema.
* My limited research implies that, geometrically, this is not a constant expansion from hip to toe.
* Rather, it seems to be a lipid blob formation centered on local malfunctioning lymph nodes (sorry, I know nothing about this and may be wrong). You may want need deep folds between these blobs to show the phenomenon properly.
* Also to be considered:
1 As lipidinous folds grow, they are subject to gravity and will sag between keyframes.
2 I assume that they must not overlap to provide a clean / watertight STL mesh (again, no idea as I do not generate 3D prints).
* In the end, all you require is n (3, 4, 5, whatever) stages of the progress of lipedema for a 3D print. This should be trivial once the basic keyframes show a clean / correct topology thereof.
* Suggestion: Upload a single leg (via area select and split) of your current STL 3D model for some experiments. BTW: You current model, wearing baggy trousers, seems to be not ideal for the purpose.
* You may want to investigate the brush tool. The geometry (quads or tris) does not matter.
* Setting radius and focus allows customising the shape of the fatty bumps.
* You can also fiddle the fallout curve do influence the shape of the cellular clusters.
:sick: PS: I discovered that feet / hands are not effected by lipoedema, so please ignore this part of my example above. I did only briefly read up on this phenomenon.
:unsure: Sorry, my misunderstanding. I thought that you were referring to a normal move or a transform which does work nicely with a soft selection.
* Yep, with push & pull I can also achieve a nice bumpy surface which closely resembles the lipoedema images in the web.
