Merging objects turns one object a dark shade.
jteix96
Member
Hello,
Im making a model and trying to merge the model into one mesh. Everything is merging just fine, except for two objects. The right arm and the left arm.
When merging these two objects, they merge, but one of the objects being merged turns a really dark shade, almost black.
This happens even when the textures are turned off.
This doesn't happen with any other objects in my model, and this problem doesn't show when rendering.
Is this some kind of bug?
Using the latest version of Cheetah 3D 7.3.3
Hi and Welcome!
Did you probably mirror one arm with/by some negative value?
Symmetry-modifier&creator shouln´t flip the normals.
Actually yes I did! I mirrored it by setting the scale to a negative value. I'll try to symmetry modifier! Thank you!!
