When is the proper time to orient joints? Before after or during heating the skeleton,?
I thought you meant posing joints. You see I don't use the Joint Tool, I use the@ Zoo,Yes using the orient tool. How else is it done?
How do you orient the joints using the Joint object tool? or is it automatic?I thought you meant posing joints. You see I don't use the Joint Tool, I use the
Joint Object from the Scene Object menu so I don't need the Orient Joint Tool.
That way my bones are always properly oriented and zeroed.
Thanks, it helps to see another workflow.A length of bones. Say you make a spine with 4 bones. When your done, pic the base bone (the one you started with) and use the orient joint tool to align the axes.
