Mirror finger joints
I can't seem to get a mirror copy of the fingerJoints to the other hand? What should I be doing? They are connected to the end of
hand bone
Yes I was using mirror copy.js
I deleted the entire Right arm bones from collar bone down to hand bone then mirror copied the entire joint structure from the Left arm. it worked. Mirror copy just the hand and fingers did not work.
I can´t recreate the issue here. And I don´t get the impression from your screenshot except the pasted joint placement.
Maybe upload the joint hierarchy only.
frank
Here is the rig, finger joints missing on one arm. this was the problem trying to mirror copy from the arm that has the joints to the one without. I choose the hand joint (see image). then mirror copy.js but it did not work for me.
  • Rig Only.zip
I think it has to do with the hierarchy. It works if you delete the character's right arm and mirror the entire left arm, but not just the hand.
Bob
Hi Bob: I'm a Bob too. (808).;)
Yes If you notice in the third reply to this thread that is what I discovered. :) Thanks though.
Always good to get as much help as I can.
Again thanks.
