Hi there
I keep finding my objects don't boolean successfully. I have grasped how to do a boolean and got it working with some of the basic polygon objects.
The problem is have is after manipulating or making my own polygon object, the boolean fails, but I get no explanation about why.
I've heard about booleans failing if the object isn't 'watertight' but how can I check that, and how can I solve that? And are there any other issues that might be causing the failure that I can check into?
Attached are the two objects I'm trying to boolean - when I try it, they both disappear, whichever order in the boolean they sit.
Thanks in advance!
Thanks in advance!
