Frank Thanks. I would like it as in you animation anchor and rope. Could you attach the file to look at and study. I need to learn this.Not sure if you want that dynamically with rope&anchor tags:
Otherwise change the Spline into a Bézier curve instead of Bézier spline with say 4 anchor points and manually adjust it (Snapping to geometry will work).
Yes that works but I was looking for a more static action no animation.Not sure if you want that dynamically with rope&anchor tags:
To have a good play interactively try this please.
1. Select "plug" and delete the 3 keyframes
2. Go frame "0"
3. Go to "Take" tab and increase "length to 30.0
4. Go in "Animation" layout and extend the scroller to the new whole take length
5. Now hit "Play" button and grab the plug with the transform-tool and move+rotate in 3d-view.
Does this work for you?
2. Go frame "0"
