video export glitches massively
Simple model of a kitchen layout with animated camera. Shows fine in render manager but exported quicktime is a mess:
https://youtu.be/8l3LPuNoKC0
Tried it using both H264 and MPEG-4 codecs, identical result.
Using a MacBook Pro OS 10.13.6, Quicktime Player 10.4
Anyone else had this problem and/or know how to deal with it? Thanks!
  • BH kitchen2.jas.zip
I´m not able to recreate this output. I rendered a low-res version and GIF and .mov files look ok:
How did you export to mp4 directly?
  • Kitchen.mov.zip
Hmm... must be an issue with my own computer.
To answer your question, I use C3D version 6.1 and it offers mpeg4 codec when saving (exporting) from the Render Manager.
Ok - thought you´re on v7 already.
Just to be sure I rendered same low-res in v6.3.3 plus HDRI and export to mpg4. No issues here. Can you update try v6.3.3?
I'll try it -- if v6.x downloads are still available somewhere? When I use the in-app Upgrade link it takes me to a page where only 7.2.1 is available for download(?)
https://www.cheetah3d.com/download.php
Thanks Frank and Martin but I'm still getting the same result with V6.3.4
:confused:
If anyone else experiences the same sort of thing, or has any ideas...
Doug
You can always convert the PNG files to MOV outside of Cheetah 3D using any decent video application (e.g. Motion). If the problem occurs when you encode that way, it's your QuickTime setup.
Similarly you could export as a different codec (e.g. PNG — lossless) and then transcode from the QuickTime Player app.
PNG worked... I thought that was only for single image files. Thanks!
