filip c
Target tag trouble
Hi Guys,
I've been experimenting with the Target tag and if I'm correct, the object with the tag points with the back of its blue coordinate arrow (its negative z-axis) to the target...
If I adjust the offset, I get weird results...
I added a test: the left cube1 is normal behaviour, the right cube2 has an adjusted offset, since I want to make the red side point to the target ball.
when the target ball is moved, the behaviour is entirely different...
Im pretty sure this behaviour is logical and I'm missing something simple...
Can somebody put me on the right track?
Any help is wildly appreciated!
also: Adjusting the coordinates of the object (and burning them) doesn't seem to help... I was planning to use the target on bones; no luck there, after a bone orient I was even less succesful and everything gets wonky...
Kindest regards,
Filip
Hi Guys,
Kindest regards,
Filip
